Kirwin said:My advice is to get the tire sidewall data IE 235/85R-16 E off your tires and go to your tire manufacture's website and put in that tires data and look up the recommended inflation pressure off of the inflation pressure/load chart or table on their website. This combined with actually weighing you truck and trailer on a commercial scale to determine what each (tire if possible) axle is carrying will provide the best recommended pressure. Note that in your owners manual packet there should be a paper from Dodge with recommended pressures for your truck. My 03 DRW 235/80R-17 E's according to Dodge require only 65 PSI for full load. Keep in mind that there is a max inflation pressure on the sidewall that should never be exceeded and that all inflation pressures are cold inflation pressures. In my opinion its better to run a little higher pressure than lower pressure within reason. Also note that in most 3/4 and 1 ton SRW trucks, rear GAWR is frequently limited by tire load capacity at the maximum inflation pressure. IE each tire is rated at 3042# and GAWR is 6084# on my 97. Hope this helps. Ken irwin
GLASMITHS said:#1 there is NOT any maximum pressure stated on the sidewalls of a D rated and above tire. There is a maximum load, but not maximum pressure. When I tow there is 90psi in all tires. This eliminates all the guess work about weights and charts and the like. Several years ago Trailer Life had an indepth article that had extensive input from Michelin and Goodyear. Their recommendation was to run up to 10 psi above the sidewall pressure that way you will not be under pressure. They also stated that if you ever run the tire under inflated, it is not IF it will fail but WHEN. Because most all tire failures are caused from initial under inflation, that causes the tire to heat up and blow. Unloaded I run 65psi all around. Loaded I ran 26K around South Texas 110+ temps in summer. Got 58K out of OEM Michelin tires. Must not be too bad on'um. :-laf
BigMike said:My E rated tire sidewall says 80psi max.
PatrickCampbell said:Really interesting about what you say RE: Max pressure. vs max load. Can you provide a link to the article?
RClark said:When you leave home, go thru Oregon. All the chickencoops leave the scales on.
Weigh the truck and trailer, axle by axle and use the chart that came with the truck to determine the correct pressure. My 2002 Ram 3500 towing a 13,000 5th wheel takes 50-55 in the front tires and a max of 40 in the duallys. the trailer can also be checked this way.
