Well, decided since I had the harness for the trailer for almost 6 months now, that I should install it...
The original wiring looked like it had taken a ride under the tires, and then had been replaced by one with road rash. The junction box was plastic, broken, and not really pretty by any means.
I took a 4x4 electrical box and some Romex connectors... the harness to the truck now hangs straight down (not bent coming out of the box) and the wiring from the trailer is fed into the box with a nice radius bend... both are held with romex connectors.
I soldered 1/4" ring terminals to both ends and used short 1/4" SS bolts with nyloc nuts to connect the trailer wires to the harness. Some might think that's butch, but I can easily disconnect them and replace the harness in a pinch very easily.
The only thing I have left to do is install a fuse holder between the harness and the battery 12+ lead, I didn't like the glass fuse hold that was there... going for a 30 amp blade tonight.
I also need to hook up the harness to the truck and ensure it does actually work (although I traced each wire to the connector to make sure it was the same)...
One more thing from the list...
