Engine/Transmission (1998.5 - 2002) truck will not start
Engine/Transmission (1998.5 - 2002) horse power and torque ratings
I started my truck and drove it around to the driveway. I let it idle, and while I was in the house I heard it stop. I went back out and tried to restart it but it would not start. I have 12 psi fuel pressure at the injector pump. All the engine does is crank, but will not fire. Any ideas?
Check for water in the filter. Also I think you can read the codes by cycling the key on and odd twice then leave on. bg
It could be possible you have a small leak in a fuel line somewhere introducing air into the fuel when the truck is sitting. If you don't have any codes stored try cracking an injector or two loose and crank it for 20 seconds at a time with about a minute in between to allow the starter to cool. You should see some fuel spurting out after a few cycles of this.
pour some cold water on the module that is attached to the injection pump and see if it will start, My 01 quit on me and it would cool off after an hour or so then start up for a while and then it would die again, took it to the shop and it was the module that fastens on the IP. , you cannot replace it, you have to completely replace the IP, but i had good pressure at my IP too, just a thought from past experience, Monte
