I just installed a new valve body from suncoast with all new solenoids and the truck wont downshift when it gets hot. When you first crank the truck and it is cold it will downshift fine but when it get some heat in it then it wont downshift to first. All of the other shifting is fine. When I installed the valve body I didnt adjust the linkage due to the fact that I didnt know how. Do you think that could be the problem? It wont downshift to first even if I manually pull it down into first. Can anyone lead me in the right direction?
I think that I had the same problem before the valve body install.
