Has anyone had a problem with there built transmission not wanting to shift at WOT? It will shift normal when just driving it but as soon as you mat it, it will not shift unless you get out of it, then it will shift. The engine will keep reving untill rev limiter kicks in but the trans will not shift. Iv had the truck scanned by dodge to see if any codes will come up that my edge didnt pick up and nothing was found. The truck will do it on the stock setting as well as the other settings. transmission guy said it seems electrical but I was hoping someone on here has had or heard of the problem before I start replacing electrical components. Any advise is appreciated. All mods are listed in signature.
