My 2003 is now dead in the driveway. I posted about a hard start condition about 2 months ago and everyones feed back was the injectors going bad and that they were a common problem. I priced injectors and I can't believe how expensive they are. I figured I would take the slow approach and change the lift pump to a BD pump installed down on the frame. Well that seemed to fix it because the truck ran and started normal. I went to start it the other day and all it does is crank. I shot some WD-40 down the intake hose and it still would not start. This trick worked when I had this problem 2 months ago but now it doesnt. I put a code scanner on it and it came up with P0366 crankshaft sensor. I put a new sensor in today and it still would not start. Do you think the injectors are the problem. The truck has 106K miles on it with no past problems. I just dont understand how the truck could run so good and then all of a sudden the injectors quit working. The air temp was 33 degrees and the grid heaters are working. Any suggestions will be greatly appreciated. Thanks, Charlie.
