I've had an intermittent hard start problem, when it happens the wait to start light does not come on and the lp does not do the normal pre start run. If I tried to start it, the motor just turns over and does not fire up. Normally I just turn off the key, try again and the wait to start light comes on and the lp runs to prime the VP.
On the way home from work yesterday I noticed that every time I idled the truck, the engine was surging up and down +/- 150 rpm. When I got home I shut down the truck and hooked up the OBD 2 to check for codes, none showed up. Since then I have tried to start it and the wait to start/lp problem is continous and the truck will not start.
With no codes to work from I am at a loss. All I can think of is that I have an ECM problem, but I am in Africa and a hit or miss "guess" on the ECM could be expensive.
All suggestions gratefully accepted. HELP!!!
Cheers,
Cam
Cheers,
Cam
