Under the hood, Driver side, When looking at the battery, on the front window side. The connector is the one closest to the battery out of the two that are on the ABS module. I am not sure on the wire, it has been a few months, but I think it is pin 12. Check the instructions to make sure, but the module is in the closest spot to the driver side font window under the hood. Good luck, I had a blast hooking it up.
