2nd Gen Non-Engine/Transmission Trying to change out a headlight bulb
2nd Gen Non-Engine/Transmission Dodge stuff on eBay
Help!!! I'm sure someone has a neat, clean, tricky way to change out the driver's side headlight bulb on a '96!!! I spent an hour on it this morning, and still can't figure it out short of pulling the battery. I got the locknut for the wiring harness loose no problem, but then what? Do you pull furiously until the harness lets loose (or your shoulder)? Or is it a twist-off arrangement?
I have the Service Manual CD and it doesn't help one single bit. I even called a buddy who is a Dodge mechanic. He just groaned and said, "Even I can't do those without difficulty. "
I tried coming in from the headlight side also. I took everything loose I could find and the headlight is still firmly in place.
I think I use to pull the bulb out with the plug attached. Then I would separate it from the bulb. It pulls off NO twisting. And Patience Jeff
Never a problem either, just pull it out.
Since you messed around with the screws in front your headlight may now be out of adjustment though.
