Not sure about putting in the #10 plate. Truck has everything needed to run it. (check out the signature) Truck pulls my 9k boat easy (16300 GVWR) Up some very long steep hills by my house. But when im empty/not pulling anything, Im not really impressed with the acceleration i've got. 60 mph+ speeds. With only the Banks stuff in the truck Rated at 265 RWHP/696RWTQ
So if I went to a #10 plate in the stock position. Is the truck likely to smoke much? What about running high EGTs when pulling, Total truck and trl wgts of 16k min, up some long hot grades? May go up 2 CM on the compressor pinwheel to help things out 56cm to a 58cm. I believe stock is a 56cm HTT has the simple bolt on upgrade. 2 cm bigger pinwheel (no housing mods)
And I could do without the turbo lag I already have :{
