Just installed a TST #11 plate and 3k governor springs, I must say that I am quit impressed! The whole job took about 6hr's and that was with taking several breaks (to help momma with our 1mo. old son).
I left the plate in the same position that the stock one was in and also reset the governor spring height to what the stock springs were. I did not have to adjust the AFC wheel, idle, or the arm that contacts the plate. I get a very small amount of smoke when I first start to squeeze on the throttle and then it goes away quickly. This is a pretty simple project with some good instructions.
Don't know yet what it did to my mpg, it will be tomorrow before I get it filled back up again. What it did do though was impressive. Before the upgrades power band was 1700rpm up to 2200rpm and would not go to 3000rpm, the 3rd to 4th shift (loaded) was like hitting a wall. Now it will pull hard at 1300rpm and really pulls at 2000rpm, it will go well over 3000rpm(I let off at 3200rpm) it will leave a cloud of smoke at that high of rpm and wot (wide open throttle) though. I use WAY less throttle to maintain highway speed now than before, and just guessing it uses the about the same amount of fuel as before.
For the first trip with the truck and trailer with these bomb's installed, all I can say is OHHHH YAAAAAHHH YOU GOTTA TRY THIS!
The great thing is, all this stuff and gauges too cost me less than $550 including shipping. I'd like to see someone gain that much power for that amount of money with a gas burner!
I'm not sure I might be hooked here?
