Just added the TST #5 plate, wow
what a difference. Took the truck out on the freeway the midrange acceleration is incredible. Can't wait to add the DTT TC/VB in the next couple of months.
I now have discovered that the abs and brake light come on when idling through parking lots and using the brakes. This is something that I have only experienced when backing a trailer and using the brakes. The last time this happened I was told this was normal due to the vacuum pump not being able to provide enough vacuum for the braking system.
I checked the vacum lines to see if any of them had come loose or came in contact with the engine causing a hole, but was unable to locate any problems.
Has anyone experienced this problem, or know what might be causing this condition.
thanks in advance>
thanks in advance>
