Engine/Transmission (1998.5 - 2002) tst and ez?
2nd Gen Non-Engine/Transmission Bent frame
2nd Gen Non-Engine/Transmission anybody out there with a lifted dually?
just wondering if I can use the ez with the tst. Im not sure what the tst does for fuel. has anyone used this? any info would be appreciated. thnaks. Dan
Yep, it works just fine.
I would prefer the Catcher/ TST combo myself.
Dave
I have the EZ/TST stacked. The TST adjusts timing and duration. The EZ with its pressure seemed to help it spool up quicker.
well I have a 2nd gen. so I donyt beleive that the ez effects pressure. I am pretty sure timing? if the tst functions primarily from timing, then I will probably just sell the ez
The EX adds timing. It also adds a small amount of fuel. But the biggest benefit to you is the timing.
The TST adds fuel only. While this has some affect on timing due to the injection pulse, it is not the same thing as the EZ.
Ths stack you are looking at works. Later on, you could sell the EZ and get a Smarty. This would be the best stack.
Dave
I dont plan on going crazy with it. I may actually sell the ez, and use the tst on the second level or like 6 on the controller. and wait till I upgrade the trans. it looks like I can get a good deal on one and I dont want to pass it up. either that or it will stay on one or two and maybe 3 for passing empty on the highway.
im still not sure though if I want to tap the pump wire for a box or just get injectors later on.
DMcPherson said:
can you hook up the tst like the comp without tapping the vp wire?
You could, but the TST will do nothing. It's only purpose is to work through the tapped injection pump wire.
So, you would have a real expensive EZ! Presuming that you have an EZ installed.
Dave
Dave[/QUOTE]
LOL , now that is funny...
just a good word of advice, using just the TST will probly mean an early death to your transmission, i am completely with you on the stack that will most likely be my next mod, but at least do a TC and VB first. If and when you do your transmission, DO IT RIGHT THE FIRST TIME!!!
yeah when I do it Im just gonna buy a complete trans. Im gonna try andnot turn it up much for now. I know I know its very tempting, but if I want to go fast I can just drive my car
