Guys,
If you have any additional fueling mechanisms, you will lose hp/tq above level 5 or 6, as BRayls stated in his previous post. If you are a stock truck and add a TST, you can run the TST up to level 9 and not lose Fuel Pressure (You will lose your turbo if you are not careful though). My best dyno numbers came at level 5x5 (575 hp/1125 tq). The numbers dropped a little on 6x6 (550 hp/975 tq), and once I hit level 7/6, the numbers had fallen significantly (475 hp/860/tq).
This was not because the TST was not doing its job, it was in fact just the opposite. As the TST levels went up, the TST called for more fuel. With DD3 injectors and a pusher pump, the pressure began to drop obove level 5. Pressure went from 26,000 psi down to 17,000 on level 7/6. On level 5/5, fuel pressure stayed right at 26,000 psi. With my EDGE EZ stacked, the torque came in earlier, and the truck seemed like it was somewhat easier to spool, but the top number went down to 545 hp (on level 4/4) from 575 hp (on level 5x5). This makes sense because with the added demand for fuel from the EZ, one has to lower the setting on the TST to maintain rail pressure, but the lower TST setting keeps max HP/TQ down.
I did the same thing as many here on the TDR and blew my single turbo on the first test ride with the TST. I was running a DD Jammer with DD3 injectors and EDGE EZ. First time I tried level 7, I sent the exhaust side of the turbo down the exhaust pipe. I quickly replaced the turbo the next day and promptly twisted the shaft on level 6. I attribute this to the injector/TST combo, which adds to the amount of fuel being delivered at low RPM and the single turbo's simply cannot handle being loaded like that.
Since the installation of twins, I have had no issues with the TST, and actually like running it without the EZ. Even though my EZ has the "secret settings", it runs better with the EZ off.
My . 02
Peter
My . 02
Peter
