When I got my EZ, I didn't see much of performance improvement on 3. I started on tooling around on Edge 5/4 EX 2. cranked it up to 3 and that seems to generate more smoke. So that was tail-gater control mode. Man does the EZ make smoke!!!
This morning I dropped the edge juice to 5/2 EZ 3. WOW, what a difference! Just as she picks up boost things start to get moving, and move hard! Funny how that little less timing on the bottom end does help on the top end as well. So once I got on 169 north from 394 I figured i'd run her up to 108mph. Just last night on 5/4 EZ 2 I pegged 1450EGT, 40psi at about 108mpg. This morning (tho cooler out (10 degrees), + Power service in the tank this fill). She pulled harder up to 108 and EGTS just breached 1300 and the boost number read 41PSI on the attitude.
I might tool around a little with 5/1 EZ 3 see if things pick up a bit more on the bottom end. One things for sure, 4/2 EZ 3. Things are slower. the EDGE needs to be on 5 (hot juice 5) to still get the most outa the stocker tubro.
I know if I get a big single, TST twins, or BDDL will have to be had in order to have the best drivability.
For day to -day driving 4/2 (or 1, not sure) EZ 2 sounds like a plan. There was little smoke at all for moderate acceleration on this setting. EDGE recommends driving on 2 anyways. This should be sufficient.
And for lets have some fun settings, 5/2 EX 3 should do the trick.
What do other people run with EDGE/EZ with stock turbo and stock/non-stock fuel systems?
