tst/ez?
Pyrometer Quality?
V A smartbox vs edge
i stacked an edge ez on my tst powermax3 tonight. with the boxes stacked the green light on my tst that shows it is adding fuel does not light up at all. any ideas why? thanks
What order did you stack the MAP sensor plugs in. When i ran that combo, I plugged the PMax in to the MAP sensor, then the EZ, then the trucks harness, and it worked great. My light worked. I cant really think of any reason why the EZ would cause the pmax not to add fuel. Maybe somebody with more smarts will chime in.
i figured out what it was. while tracing wires i found the inline fuse by the 9pin connector blown. replaced fuse and now the pm3 adds fuel. but know for some reason when i step on the go pedal i can't tell if there are any cars behind me or not.
