TST-not sure?
air filter question
Transfer case ?s on '05
I also seem to be getting 1. 5 - 2 mpg increase on my '03. I've been very happy with the TST PMCR since it was installed it in May.
Does anyone know what the fourth "screen" on the in-cab controller is for on the PMCR equipped with gauges (e. g. , the second "screen" is to set max egt; the third "screen" is to set the torque enhancement level - "tE", etc. )? It looks like it has a "bt" or "6t" in the "boost" window and a variable number in the "egt" window.
BT - Box Temp. It measures the temperature of the box itself. I had heard it was put in there during the proto-typing/testing period, and just never got removed.
-Tom
That's correct, the temp of the actual module under the hood. If it gets too hot it will shut down and the truck returns to stock fuel settings.
-Scott
