TST PMAX3+ Edge Comp
FASS system
truespeed
Is it possible to run this combo? Using the Comp for timing only you could turn off timing for towing while using the fueling from the TST. And you could also adjust timing on the fly. Obviously you would leave the pump wire from the Comp off, but which would you use for the MAP sensor location?
Install TST PM3 box harness connection into map sensor, then the edge connection.
Use the fuel pump wire from the TST box.
Use the data-link connection from the Edge box.
This should work!
Be careful.
--Justin
