tst powermax CR / Smarty Stack Question
Muffler Delete and Fluttering Noise
Mp8
I know which timing settings are on the smarty, but what settings do what on the tst. I need some good power and i already have all the upgrades like transmission, turbo, etc, etc. Just trying to figuire out what is what on the tst like the reg. 9 setting then the torque settings and what they actually do. Thanks
On the TST you can add TST one degree at a time, or you can set it to dynamic timing. When I ran that stack I increased timing until it rattled a bit too much, then backed it down. Depending on your Smarty program, injectors and model of the motor you will have differing results with the same amount of TST timing advance.
They used to have a pdf of the owners manual available on their website. You might check that out to show you what the controls are.
