Engine/Transmission (1994 - 1998) TULSA,OKLAHOMA Area For Timing
Engine/Transmission (1998.5 - 2002) Mach 1.6 or mach 2's?
2nd Gen Non-Engine/Transmission driveline whine
Is there anyone in the Tulsa, Oklahoma area that could advance the injector pump timing on my truck? I really need to get it done.
Thanks in advance. . Kevin :D :D :-laf
Kdp
:) Hey David, I just got my timing advanced by a guy named Doug at Diesel Power Plus in Broken Arrow. His number is 918-625-8191. He does all kinds of work on diesels.
You can do the KDP yourself with TST's fixit kit for about 50bucks and a couple hours of your time... ... . I know that Doug does it because he showed me the tabs he puts in them.
Kevin :D
Thanks Kevin, I've read the kit instructions and am considering doing it myself, will probably order the kit soon. I appreciate the tip on Doug at Deisel Power Plus as I'm having a starting problem that needs looking into. Great to know I can count on the members for help! Sorry to take so long to reply, been on the road (but not in the truck).
David
Kevin. .
If you do not mind a small trip then one of the sharpest 5. 9 mechanics is just a short ride awy from you right up I-44 in Missouri. He is a TDR Member and goes by Rammin On and his shop is called "Forest City Diesel" and its located about 4hrs East of you in St. James,MO right off I-44. I am certain when I say this that Kieth has many fine running Rams that have been thru his shop. Many TDR and DTR owners have been tuned by him and when you run across one you will easily see him by the smile from one ear to the other. Drop him a PM and I am certain he can take care of whatever you wish done... ... ... ... ..... Andy
