I got the P00AF “Turbocharger/Supercharger Boost Control A Module Performance” code about two weeks ago. I hadn’t noticed any change in performance or anything so I deleted the code.
This morning the code came back, and since I didn’t notice any change in performance so I deleted the code again. While almost home, the turbo charger appeared to stick with the exhaust brake in the on position. I stopped on the side of the road and let the truck sit for a couple of minutes. When I restarted the truck I did not turn the exhaust brake button on. I have been able to drive the truck with no problems since and the turbo builds good boost.
From what limited info I can find, the module is fairly easy to replace, but I’ve found conflicting information on if the module has to be calibrated on models newer than 2012. I’ve also read a couple that say the turbo will likely need replacing or cleaning at minimum soon.
Looking for some guidance. Truck is currently at 108k miles and was deleted less than 2000 miles ago.
Edit-I also have an extended warranty not through Ram, that goes until 125k that is supposed to cover this, but not sure since being deleted.
Thanks
Craig
Thanks
Craig
