My friend has a 2014 dodge ram turbo diesel, and his check engine light keeps coming on. I took my code reader and found it had thrown several codes relating to the turbo. Most codes would delete, but it kept throwing a code about the position of the actuator being beyond it's expected range. I figured it would likely be the actuator's "encoder" or position sensor could be the problem. He would like to consider replacing the actuator by itself, but some shops want to replace the entire turbo and actuator without any further consideration. Any suggestions for a best fix for this?
1. Can the actuator be replaced without changing the turbo also?
2. Can a cummins part, either actuator or turbo or both be used, or must one buy from Dodge?
3. Any further information on this would be helpful.
P.
P.
