Engine/Transmission (1998.5 - 2002) turbo, and injector questions
Engine/Transmission (1994 - 1998) fuel knock
i have been looking for awile and i cant decide between the HTT HTB2 and the phat shaft 62. anybody have these, if so how do you like it?
also what are the best injectors on the market and have the smoothest idle? i've hear good things about the jammer injectors, and was actually serious about their stage 5's for awile
dallan, i would consider putting the sps 62 to the test, they are an awesome turbo, and spool way faster than stock, they are limited to 600hp so make that help you deside on the size. as for the injectors the II dragon flows are the hottest injector for the 24 valves at the moment, the jammers are good too though. hope this helps
love my sps. . great spool and keeps things cool with the 150hp sticks while towing. I love f-1 sticks for the smoothness and dyno proven power. Also burn clean too. Lots of good makes out there though. Don't know the price of the other injectors but I've heard that f-1's are also the most expensive :{
High Tech has done an awesome job on the Super Stock 62 and they're tough. DDP - Dynomite Diesel - makes an awesome injector and the cost won't kill your wallet either. Edge nozzles are good but if you're looking for the best don't be scared on spending the money on a good set of sticks.
I second that..... the Dragon flows are awesome & idle better than stock. They can get a little smokey, but power is unbelievable. If you aren't afraid of smoke... . I think you should go this route... ... just follow my advise Dragons & Super Stock 62. Awesome combo. ;)
where can i look at the dragon flows? also, i run at about 1250egt right now and if i put stage 5 injectors in and the sps or the htt, how hot will i run?
Dragon Flows are made by Industrial Injection... . with the Super Stock 62 turbo, Edge Drag Comp on kill, Smarty on #8..... I saw 1400* wot. I recently switched to a 4 flow [125hp] injector "dragon flies" from I. I. & now at WOT I only see 1200 max with everything on kill mode. I tow heavy & love my current setup, but miss the dragon flows when I wanna have fun. They are awesome injectors. The 4 flows are unbelievably clean... . without Smarty I don't even smoke at all..... which is nice when I am towing.
i have a link @ the bottom of my sig, it will take you from there :cool:
I'm running stage4 edge nozzles and i like them! they idle just like stock. truck fires off just by bumping the key! I also just ordered a HTT 62/12 from RIP it will be here, hopefully fri. i'll post on how i like it. At least everybody so far has told me IT'S AWESOME! I can't wait!
so cummins724, you have stage 4 dragon flows, it that correct? what did you have before? how much does a set of those injectors that you are running cost? thanks
They are called 4 flow injectors by industrial injection..... some guys call them Dragon Flies. The Dragon Flows are the next step up..... the 4 flows have 7 holes. The dragon flows have 10 holes. I paid $650 for my Dragon Flows... . the 4 flows are about the same price wise. I would buy the 4 flows if I were to do it again..... the Dragon Flows are bad azz, but they smoke alot... . especially at low boost. The 4 flows are clean even with my comp on 5x5..... When smarty is stacked with comp..... they are pretty smokey at times.
Dallan said:
for some reason i cant find them on their site
They are special injectors designed for race... . custom made. They aren't listed on the site. You need to contact I. I. by phone to order. I got mine from ETR. He usually has them on stock.
