Details here: TDR Privileges
timbo, noticed that you are running a aeromotive fuel pump, which one and is that piggieback or replaced. i am looking at the ss fuel pump(part # 11203) for replacement. but i am going to see what my injectors pull (stg 3) first ,cummins atlantic said if my lift pump is good it should supply enough for that stg. injectors, we"ll see.
I have used the Aeromotive SS pump worked OK but would leak fuel in the winter also after stepping up to the F1 Mach 7s would not keep the psi. changed out for a FASS 150/150 keeps the psi dead on 20lbs. To maintain fuel psi you need a pump with a bypass like a FASS system that returns fuel till you need it!
