Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Turbo Boost with Elbow??
Nitrous Solenoid
New Injection pump going in today -
Just received a PE Edge EZ and will install it soon. I did some searching, but didn't really find the answer I am looking for.
How much boost should I expect with EZ and the boost elbow installed. I see 20 psi max under load now and am curious as to what the boost elbow will generate? Additionally, what change in EGT's will I see with these installed while pulling the 5er? Other than straight exhaust and K&N, the truck is stock.
Thanks in advance for any info.
Dave
I went from 18psi to 28psi with the wastegate disabled. It will peak at 30psi then drop back to a steady 28psi. Also seeing a major drop in EGT with the extra boost. Does not feel like the extra boost added any power over just the EZ.
Stock:
22 PSIG max boost
1250-1300 degf max pre-turbo EGT
With EZ & elbow:
32 PSIG max boost
1050-1100 degf max pre-turbo EGT
Rusty
Thanks for the replies. This is about what I thought it would be, but wanted to hear words of experience.
I was hoping with the increased fueling I would see a drop in EGT's with the boost elbow. Does anyone see a noticable change in fuel mileage?
Dave
Dave,
I think your going to see different readings, depending on your truck setup (i. e. auto, manual, 5sp/6sp, eth/etc, and boost elbow mod vs. wastgate turnbuckle mod). On my stock ETC 5 spd, with an EZ and non-adjustable boost elbow, my boost went from around 18psi to a max of 25. Called EZ and they said this is about normal for my setup... ;)
