I got my prototype from the machine shop. Preliminary tests show higher boost at partial throttle, and faster turbo spool up... . I can not give you a time to achieve full boost since I do not have a data logger. But I can tell you there is 1 psi at idle, 2 psi at 1200 rpm under compression, and 3 psi at 2000rpm under compression. I have an Ashcroft 0-30 psi gage . 5psi increments I will be hooking up once the aluminum piece is done. The engine also seems more responsive at lower rpm's. A 60 to 90 6th gear WOT run showed only 900F for EGT. Ambient air temp was 52F with no wind on a level road. Turbo noise is almost absent compared to the stock turbo without the silencer ring. You do not even know the turbo is there untill 15 psi, and even then you have to strain to hear it. I will be doing WOT testing once I have an aluminum one that can withstand the heat. So far it is looking good! In case you want to know my truck is a 2001 ETH DEE QC SB 4x4 3. 55 gears 35" tires, 3"lift 275 injectors, boost module and elbow set for 30 psi max boost.
