I had a catastrophic turbo failure on my signature truck this weekend. I was driving on the highway at about 45mph, unloaded, and did a near full-throttle (5th gear) passing attempt when a loud pop like a shotgun went off and lost power immediately and trailed a ton of white/grey smoke. I quickly pulled off the highway, shut down, and looked around for oil or pieces of the engine on the ground. Saw none and started back up with a little shudder in the engine, but managed to idle/low throttle myself off the highway to await a tow home.
Once I got home, I pulled the intake off the turbo and found the compressor to have completely failed. Turbo/exhaust manifold and intercooler all came out yesterday and I'm going to definitely need a new turbo and possibly a new intercooler. I'm worried about metal parts having made it into the intercooler. There's definitely some oil coating on the intake side of it, but the exit of the intercooler is still clean. Can the intercooler be trusted again?
I'm wondering what could have caused the failure. I've been running a Smarty on level 3 for about 40k miles. I also recently (about 10k miles ago) installed a new exhaust manifold because the stock one had warped enough there was a small exhaust leak. I put on the two-piece BD manifold and that solved my exhaust leak. I occasionally tow heavy (truck camper and car trailer) and am pretty careful to let EGTs cool down to ~300 before shutting down after towing, but I cannot say I've been perfect about that.
So, I'm hoping to figure out if this was just a failure of the turbo due to age or if I have a more fundamental problem going on that needs to be looked at. The truck was running perfectly before this failure with no odd noises and could make ~30psi of boost. Here are two pics of the failed turbo. Any ideas out there if I have bigger problems going on?
