Turbo Master
source for replacement carpet
Xm
Anyone have a Turbo Master boost "controler" as advertised on the TDR site? What is it, how does it function? Does it also act as a boost "fooler" to prevent setting over-boost code? Thanks in Advance, Jim G.
yes they do...sort of
The Turbo-Master fits all '94 through '98. 5 12v and 24v Rams. It will also fit later 24v models ('99+) if you have replaced the turbine housing with the Banks style Quick Turbo for example (where the wastegate actuator is located BELOW the turbine housing).
