Engine/Transmission (1998.5 - 2002) Turbo Modifications(2)
I am thinking about replacing my turbo. I want to know if it would work to install the banks big head and the brass nipple with the orifice coming off the turbo that I got with my edge comp chip on the same turbo. Or should I do one or the other and not both.
The Big Head will set your waste gate at around 38 psi which is all you should go with your turbo. I'd say one or the other, not both. The HX 35 is a good inexpensive up grade from the HY.
I agree with darkhorse, I ran both on mine once and was hitting 45 lbs which is juuuuusssst a bit too much for the stocker
