I'm need some help... ... ... .
A few months ago I started hearing a weird noise while making boost. It was fairly quiet and not to noticable. Recently, I changed out the stock air box and K & N filter with a ASA modified intake pipe and an AFE filter (stock box is gone).
The noise is much more prevalent due to the new intake and is easier to describe now. The noise sounds like a "flutter" or like a propeller "cavitation". It only happens when boost is building but isn't at all consistent. Sometimes the noise will happen, sometimes it won't. Sometimes it will happen at 12 psi and other times at 20 psi. I can back off the gas and drop boost and noise will stop, then re-gas, boost will build but this time the noise won't come back. It seems to happen more when I'm pulling a good load. Weird.....
The boost doesn't fluxuate nor is the power any different when it's noisy... so performance doesn't seem to be affected.
So, any ideas? thoughts?
Rich
Rich
