My brother just picked up a '02 Auto with 68,000 miles. His first Diesel. Last night we took the intake hose off and were about to do the silencer ring "mod" when I started looking closer at the compressor. There was a little oil on the inducer, after cleaning that off I grabbed the shaft nut to check for endplay. Seemed very little if any, however up and down there appeared to be some slop. Upon removing the silencer ring, we found a bit of oil behind it as well. We decided to put the ring back on this time bomb and take it easy. It seems to spool ok, but I dont want him to hook to anything and grenade it. Truck has no mods except a puck that was on it when the Dodge dealer sold it to him. (score!)
Questions... What is the specification for allowable shaft play?
Does it sound like his HY is junk?
With 68 k and no real mods, is this a warranty item?
If not, can you recommend a little bigger turbo he can run now that will give him a little room for bombs but still spool well with his current setup... low buck is good. I pointed him at a City Diesel DZ or PDRHX35?? His pockets are kinda tight as he just put down a chunk on this truck, so if its a warranty item, he'll probably go that route.
Sorry if any of these are duh questions, but the crowd we run with usually replaces turbos because they WANT to not because they HAVE To. :-laf
