Details here: TDR Privileges
I always see turbos mounted with the shaft parallel to the ground. Can they be mounted at angle? Or even perpendicular?If not I assume it is a lube issue?
they can be mounted with a SLIGHT angle if space constraints require it, but they really should be mounted parallel. It's a lube issue. more specificly a lube drain issue.
