They both should be 18. 5cm. On the housing there are numbers in the casting on the side that's facing the firewall. The numbers are on the fat part of the housing right next to the flange that connects to the exhaust manifold. You'll find either "18. 5" or "21". To see the numbers, you'll need a mirror or you'll have to climb up on top of the engine and look down. FWIW, the number is referring to the cross sectional area of the turbine housing inlet port in units of cm^2. Also, the housings are interchangable with no modifications.
Cheers,
Sean
