Turbo Questions
Trade 6" rear blocks for 4"?
Replacing Fuel Tank Sending unit
Can someone tell me the difference between a WH1C and WH1E turbo?
Is the WH1C compressor housing the housing to use on the H1C to gain the bigger outlet and 60mm inducer?
No. When you buy the upgrade, you will recieve a housing to match the wheel. If you want a 58mm wheel, you'll recieve a matched housing be it H1 or WH1. The W is the gated turbo. Some have a port for the boost signal and some do not.
If you want the 60mm wheel, you will then recieve a housing. Again, be it WH1 or H1. Some of the wheels will be a direct fit. Others, will require machine work performed to the backing plate.
I am running a WH1C compressor wheel and housing that I mated to my stock "baby" H1C. I think the wheel is 56 mm, but it might be 58. I know the standard housing from a 92 I/C cummins would not fit.
The WH1C housing also has the MWE slot that eliminated my turbo flutter.
So yes this will be an upgrade for your non I/C turbo or "baby" H1C.
Jay
