Im with powerwagon too,with the HX35,from what I've read,you dont want to make any more boost than you need,since the turbo becomes very inefficient at high boost,a few things happen when you use to much boost,first the drive pressure(exhaust backpressure in the exhaust manifold becomes very high,because your forcing all the exxhaust to go thru the turbo's housing at high rpm's,high load,if the wastegate functioned right,and opened,it would allow excess air around the housing,reducing drive pressure,and actually improving airflow at a certain point. Now on the intake side of the turbo,the HX35 is good to about 33-36 psi,above that boost level it starts to make a lot of heat,but not much more boost,so the air temp rises quickly as boost goes over 35,so there is no beneift to boost higher that 35 or so,with the stock turbo,now the HX40,or the B1,and other turbo's are still in their efficiency map at 40PSi,and higher,those turbo's will improve performance,and higher boost is a benefit,but if your runing the HX35,I would keep the boost at 35 or so,max. I can get 31 psi,with just the DD3's,and a boost elbow,but with the comp on level 5,my boost only goes up to 37-38 peak,this tells me,im way off the map of my turbo,and its inefficient at that HP,but im not $$ ready for the B1 yet,although i feel tis worth every penny.
