"Mad Max"
I wanted to clarify some thoughts regarding detecting wear on a used turbo. After searching it seems the general consensus is side-to-side play (with no scraping inside the housing) is okay... and not unexpected... but end play (front-to-back) is not good. Correct?
I've got a used 2nd gen HX-35/12wg combo going on my '93 and it has some side play - enough that I have thought about rebuilding just because I can, but as far as I can tell the blades are not touching the housing. No end play. From what I have read that should good to go, ja?
Many thanks,
- Sam
Many thanks,
- Sam
