Hello all im a little new to the game. I have a 1993 F350 4x4 4 door ZF 5 speed 3.73 gears on 35 inch tires
I have installed a 1992 Gen 1 5.9 out of a wrecked truck. engine mods are a dps fummins exhaust manifold for the 5.9 in a ford conversion a HE351cw with the servo removed and plugged full for inch exhaust with a straight through muffler (im happy with the sound - no droning when towing) I installed 5x12 vco 145 angle injectors from The Hungry Diesel I had the injection pump rebuilt at Oregon Fuel Injection with there off road tune a BD fuel Pin and a 3500 rpm spring I stalled a upgraded 3 inch intake and IC tubing and a 1999 power stroke inter cooler.
before rebuilding the injection pump i played with all the settings i was getting over 40 psi boost and smoked like crazy but it was fun but i built it for towing so its set at Oregon fuel injection off road settings, with 0 deg timing im making about 37 pounds boost and is very drivable and ok power towing
my toy hauler weighs about 13000 loaded on the freeway it tows great but on the long steep hills im trying to keep the RPMs up but as i lug down my temps go up and i shift down i end up at 35 mph in 3rd gear and i try to keep the egts no more then 1200 deg, I ran the temp up once to 1450 egts and got right out of it.
Is this normal or Am I expecting to much out of this combination
i talked to The Hungry Diesel and he recommended up grading the turbo to a Borg Warner S362SXE
( https://www.thehungrydiesel.com/product.sc?productId=2117&categoryId=350 )
to get rid of the heat and faster spooling
thanks for any advise or experiences
Brad
sorry for the long post
Brad
