Engine/Transmission (1998.5 - 2002) turbo
Engine/Transmission (1994 - 1998) 1st/2nd gen injector question
Engine/Transmission (1998.5 - 2002) Clutch Installed
2001 2500 TD auto have hx35 turbo. banks brake. 4'' pipe from turbo out back. banks intake tube. stage 3 injectors edge comp. a inline helper pump. 20#pressure. full set of guages. AFE air filter. ats triple lock torke converter. ats valve body in tran.
I would like better turbo I have ben told that the hx35/40 hybrid is the only one that will bolt up to the banks and if this is so will that be a good turbo for my mods.
thank you Oo. Oo.
The hybrid will flow much better than the hx35 that you have, but If you plan on going with more upgrades later... . You will outgrow it soon.
2001 auto factory turbo is HY-35 very small 9cm exhaust housing. A 35/40 hybrid would be a great upgrade and you can keep you turbo mount brake with the 5 bolt flange. If had a v-band clamp brake there are other turbos. You could cut off the 5 bolt flange weld on a 4" v-band flange and run a HTT turbo?
