Turn signal/headlight dimmer and wiper control
92 interior parts
Bad injection pump
Help! I've got a 1990 1st gen and the turn signal control will not control the headlight high/low beams. I can pull back on the control stalk and get both hi and lo beams on, but I cannot select hi OR low by pushing forward. Where can I get a new/old and functioning switch? I've looked but can only find a switch with the emergency flasher function included at the top.
Yes Sir. Every time mine have failed I would have what you describe, no headlights unless the turn signal dimmer switch on column was pulled back.
I have headlights, but no ability to select the high beams unless I pull back on the turn signal switch, which powers both high and low beams. Sorry I didn't explain better.
The switch on the steering column is called a Multi function switch and should still be available from any Chrysler Corp. dealer. That switch was used for quite a few years. You will need a locking torx bit to change it.
Bob
