I am wiring an additional side mounted turn signal indicator on some cargo trailers we use for work. I do not want these lights to run with the brake lights switch as they would also illuminate with the brakes. I have located and tapped into the 18gauge wire that feeds the turn lamps circuits for the front. My question is if there is enough juice available to power an additional lamp from this circuit or should I use a relay? We tried them already just using a test, and there was no problem, but I just thought I'd check a bit further before completing the wiring.
Kev
Kev
