Twilight Zone
Aftermarket Projector Headlights
AAM front axle ujoints
Installed two new batteries recently in the '08. Suddenly the dash board cut in and out, speedo stopped working, and she threw
Codes
P2509 ECM/PCM Power Input Signal Intermittent
P0501 Vehicle Speed Sensor
U0121 Lost connection with Anti Lock Brakes (ABS) Control Module#@$%!
First thought was the batteries but they were a little low no big deal, alternator tested fine as well...
Anyone had a similar experience????? Thanks as always... ho Ho HO!
Keep driving and the ECM will learn it has new batteries. At least thats what happened when I changed batteries without following the recommended procedure. The codes just went away after a few driving cycles.
Keep at least one battery connected while you change them out so the ECM doesn't suddenly lose 12 V power. I had a CEL for 3 days. The service guy at the dealer said to ignore and keep driving, just need some engine cycles is all.
Ya that's exactly what I did, read too many post throwing codes when disconnecting the whole system
I just changed batteries last week. I did them one at-a-time and used a pair of large gauntlet leather gloves to insulate the terminals when they were disconnected. Looked kind of funny, but worked perfectly.
2006 Ram 2500
