Engine/Transmission (1994 - 1998) Twin turbo 12V Jeep!! Check out these pics!!
Engine/Transmission (1998.5 - 2002) Need ECM help in SE MI
RSchwarzli
Many of you know MBRP Performance exhaust. They are pretty much the leader when it comes to exhaust for our trucks.
What many of you might not be aware of, is the folks who run MBRP are very much car enthusiasts. More so, Cummins fans.
Being that MBRP is only a 2 hour drive from me, and with my involvment in the Diesel world, I have come to know the powers that be over at MBRP. I was alerted to a project that they are working on, and with their permission, I was allowed to share this info with you.
Here is one of their newest projects you folks may get a kick out of.
This is the final result/mockup:
They are using a entire motor/trans from a Ram, lengthening body, modifying frame, and making it all work together!!
The starter two vehicles that will become one!
Its nice to see some 12Vs getting the respect they deserve and going into high profile show vehicles like this!
That the bulk of the pics that I have! Will see if I can get one of the engineers over at MBRP to post some more updated pics and the specs on the motor and driveline!
Robert
Nice!!!!
Leave a trap door on the firewall there and one can have a handy sandwich warmer next to #6 cylinder. :-laf
This is one of those,already been done deals,but,with an older Jeep.
Back in 03 or 04,forgot which year it was there was a lifted Yellow Jeep CJ7,tilt front end with twins hanging on it. Never seen that Jeep again after that show and often wondered where it went.
There was a newer XJ/YJ(not sure which it was)built with a full tilt Currie suspension with flipped axles and a twinned 4BT on the net for sale in Texas a while ago also.
Are you playing with two engines? one with a hastings filter on it and the other with a Fram? This a project that has to be right the first time cause you not going to fix it later.
Modify the fire wall and dash to do a overhead or just pull the engine?
Quite the under taking. Good luck with it.
Only one motor! That was done just to confuse you! :-laf
