Here are some pictures of Piers's new TT's. I'm not sure if this is the exact same one he'll be offering us. This is in a Suburban. Probably a different engine compartment.
http://www.piersdiesel.com/Projects.htm
From what I have heard thru the "grape vine". The primary turbo is Piers's Hybrid HX-35. It looks like it has a HUGE exhaust housing. The secondary turbo is a Garret w/ a 5" downpipe.
I read in a post Piers's TT's can produce up to 120 psi of boost. I wouldn't use that much. That's asking for a blown head gasket & stretched head bolts, blown out intake gaskets and intercooler hoses. Especially on our older thrucks. ( just speculation)
It shouldn't effect you A/C componets.
I"m not 100% sure on Dave Mitchell's TT's. I know you had to relocate the right side battery (like slybones said)
It appears one thing we will need to do on our '94's is change the oil pan to a modified one. This will require raising the engine on one side.
Holeshot,
You are probably going to need some heavy fueling to spool these twins up. They are designed for engines making 350 hp and up. As I read your signature, you'll need to upgrade injectors, delivery valves and get a strong torque plate. Thats the minumum. Even with those 3 mods, you still may not have enough fueling to get them work like they are designed too.
If your ready to buy one, all is I can say is: "I wish I had your job"
If anyone sees any errors in the above post, please correct me
