Competition twin turbo edumucation
Competition Sigma's Competitor
Competition Traction bars w/ delron bushings ??
ok so im thinking about the twin set up that i would like to do. now i know all your thoughts on the stock turbo in twin apps. but here is the idea i would like to put an hx35 14cm2 and an ht3b.
the plan as it stands is to flip my ats manifold over and mount the 35 there, then mount the ht3b on bottom as normal. now my questions. 1. do i need an external wastegate or if i open the 35 so that it vents all 6 cylinders will it be fine? 2. how will all the aftermarket parts fit with both turbos being mounted higher? concerns are oil lines and intake tube to the intercooler. 3. since i got one turbo for free and possibly the second though its not in my hands yet. i was hoping that maybe people on here had the parts for this kind of set up for much cheaper then buying new or maybe even free.
for now those are my only questions im sure ill have more but let me know what you guys think besides the dislike for the top turbo. i would also like critques(sp?) if you have any. thanks matt
piers used to mod the wastegate in the stock housing by opening it up and boring it to the other snail to eliminate the need for a external wastegate, it was pretty cheap if i remember right, but again it was a few years ago so dont quote me if thier still doing it.
as for the ht3b i belive the best setups were using 26cm ex housings, and i belive there is a drain on the block of your truck. making all the hoses is the easy part, its the big pipe thats a little time consuming. i made a set of twins a while ago but sold them before i installed them so if you want any help or ideas feel free to ask.
matt
