Things are looking good!
Well, I have some preliminary numbers, but haven’t been able to “really” test the set-up yet. Before doing so, I need to do a few things.
To start, I need to obtain an air filter before going any further with test-drives. I originally planned on installing the BHAF Napa 2790, but my local dealer wanted $55 for it (too much money in my book for a throw-away filter). So I decided to order a KN-0880 a few days ago from Jeg’s, $56. 19 to my door, far better than the BHAF. I still believe I can use the stock filter housing with a redesign to the cold side piping, I just hate to cut up perfectly functional piping.
Secondly, I need to let my replacement clutch seat before adding any additional power. The new design SBC clutch is a very nice improvement over the old one. Engagement is far better. I’m looking forward to putting this clutch through the paces.
My base lines before the twin set-up are as follows:
TST # 11 plate.
192 delivery valves
300 marine injectors
Stock governor and AFC spring.
16HX35 (Piers Turbo)
4” exhaust.
Peak boost 40 psi, max egts 1400 (against governor)
To date, with the few runs around the county test roads I use, this is what I have observed with the twin set-up. I have made no fueling adjustments.
3 psi of boost at 1000 rpm
30 psi of boost at 1500 rpm
48 psi of boost at 3000 rpm with a peak of 72 psi of backpressure and roughly 1280 max egts, this was against the governor. The only smoke I observed was against the governor, other than that it’s pretty clean.
I was able to reduce the peak backpressure psi to 68 by adjusting the primary waste gate to a lower value without affecting the peak boost value. I’m not sure if that would actually make a change on the peak backpressure values, however that’s what I observed. I’m still debating those results.
From what I have observed so far, this set-up looks very promising for towing and low rpm grunt, but with the 68/72 peak backpressure reading I wouldn’t try to go for real big horse power numbers. For that you would want to look at what HVAC is running.
Once I receive the KN-0880, hopefully Friday, I’ll start doing some better testing and be able to provide some concrete numbers to compare against the base line. Then I’ll change injectors to the 370’s and start playing around with fuel plates. I have a couple from Piers that look pretty promising. I might even install the governor spring kit again, I just need to finish installing the 60lb springs on the intake side.
What ever happened to Sport Bike? He was one of the first I remember who was fabricating a homemade system. Actually, he was the one who’s efforts inspired me to fabricate my own.
The funny thing is, I am already thinking about using some different turbos, but that’s only in the day dreaming stage.
