Engine/Transmission (1998.5 - 2002) twin turbos
2nd Gen Non-Engine/Transmission Should I add R-134?
Engine/Transmission (1998.5 - 2002) P0751 and P1693
does anyone know of a paper filter with a 5inch opening that i could put on my bd tow twins? i have the oiled filter that comes with the twins but would much ranther run a dry paper filter... .
Ahhh, what does that outer measure?
I looked at using one off a freightliner bus for the ones I used to have on my '96... . Part Detail Inside diameter is right at 5 1/4"... . You'd need some kind of restraining strap if you're going to place it on the front of the filter... .
Also, aren't the AFE Proguard 7 series filters 5" where they attach to the filter box? I'll have to check that tonight... . I've got an intake system in stock...
