I am building a set of twins, running an HX35/40 hybrid on top and a B2 on bottom. I am trying to find out what kinda boost numbers I will see on a 99 ETC with O-ringed head 10thous. over gasket, Mach7's and a drag comp. I am about to order boost gauges and need to decide what range to get. I am planning to put a boost gauge on the cold pipe so i can see how much boost the B2 is putting out and then of course a gauge to see total boost. i figure a 0-100 for the total boost, but don't no about the boost out of the B2 0-35 or 0-60? Also would like to be able to see drive pressure so I can better tune waste gates and decide if I need to go to a HX40 exhaust housing. What do you guys use to monitor drive pressure? I guess I could just use a boost gauge but not sure how much steel line you would need to run to deal with the heat? Thank you in advance!! Lowell
