Engine/Transmission (1994 - 1998) Twins EGT s???
Engine/Transmission (1998.5 - 2002) causes of ecm going bad
2nd Gen Non-Engine/Transmission Thuren trackbars?
ambient temp plays a bit of a factor as well as road grade, keep in mind I also have 37 inch tires
Idle is about 200-250 and crusin' 70mph 750-850
A properly designed set of twin turbos, like the BD set I have, will reduce highway and towing egt 100 to 400 degrees compared to various single turbo setups. Idle egt won't be affected. A good intercooler like BD's will also reduce egt, often 100-200 degrees.
I know my cruising egt's went up a bit, but that is to be expected I think since I am using a stock turbo on top and in low boost situations you have added restriction in the exhaust with the second turbo, that is not pushing any boost in my case. However peak egt's are down to 1275 from 1850.
