does any one know if someone sells a kit of just the piping? and if so do they have it for a hx35 and a bht3b combo?
TCluff said:DOES ANYBODY KNOW IF SOMEONE SELLS PIPING FOR AN HY-35 TO 3B-26FOR AN 03-05
MCummings said:I broke the block on my truck with an HX-35/12 and 3B-22, so I'd be very carefull with what you do.
A 35 with a bigger exhaust housing or even a '40 on top is the way to go.
Merrick
MCummings said:I'm not complaining of a broken block.
I think the stresses my motor saw with the baby turbo's were more than some other more powerfull setups.
Was it a 53 block? Yes, but it didn't break were they normally break, unless they all break from the thrust bearing and up around into the cylinder wall stopping just below the piston rings.
*I* think I floated the valves and rocked a piston in the cylinder.
Merrick
MCummings said:On a 35/12 - 3B/22 I was doing 520rwhp.
Only changed the exhaust housing on the 35 to a 16WG'd and haven't hurt the motor yet. However, it blew up within 2 weeks with the 12cm housing (non-WG'd admitadly)
Merrick
TCluff said:could you run an internal and external waste gate at the same time like if you were running a stock hy-35 and a 3b-26, to keep the drive pressure in check, or would intake air not be able to flow fast enough through the hy-35, around the 600 h. p. level ???????![]()
Jim Fulmer said:Yes you could do this but I don't think anyone makes a piping kit using the HY on top for a 2nd gen. Most kits are with a HX on top as it is the most popular..... supply and demand. There is really not any money in Twin kits or building them unless you can get to the point of making parts on a Jig. Making a kit on the truck is a PITA in my eyes, I've done 3 like this and it's #3 in the worse jobs to do. Engine swap is #1, Cam swap is #2 and I've done them all.
Jim
