I'm doing some research for a friend, pretty much I get to spend someone else's money. Anyways, the truck is an 06 auto 4x4, and the primary use is going to be towing, nothing too heavy but his last truck which was about 550hp got really really hot even towing a jeep with the box turned off. The plan is to get the transmission done middle of next month, then add a box, probably the TST powermax, and then maybe twins and injectors. Is the powermax enough fuel to spool twins. He isn't looking for anything super high horsepower, probably in the 450-500 range. He just wants to be able to use that power towing.
Next question, what turbos are you guys running, is there an already built set that works wonders or is custom fab the way to go(it is an option, if we need to go that way).
Thanks, sorry this was so long
Sean
Sean
